Manual foot pedals to automatic foot pedals?
rr4406pak
Marion, NY
I've got a 69' Swinger that has the 3 pedals for the use of a manual transmission.
I'm converting the car to a floor shift automatic transmission.
Is it possible to swap out my manual 3 pedals for an auto trans 2 pedal setup?
Also, are the different pedal setups master cylinder specific?
Thanks.
If you want to swap automatic parts for your manual parts I'm interested in what you're taking out and will pay cash and have the parts you need...
But yeah back to your question just put the automatic stuff with the auto push rod and your same master cylinder will work
Do the old pedals just unbolt out as one big unit and you bolt in the new unit? Pedals and all?
.............I'm converting the car to a floor shift automatic transmission.
Is it possible to swap out my manual 3 pedals for an auto trans 2 pedal setup?.............
I ran an automatic with a cable shift in my 4spd '69 for a couple years. All I did was let the O-C spring hold the clutch pedal to the floor.
Was glad I didn't pull the peddle out as I decided to go back to 4spd.
