marker lamp replacement
moparstilldeath
Active Member
Attica. Mi
Is it possible to just change the front marker lamp bulb in a 68 barracuda.
if so how does the asm come apart?:banghead:
If my memory serves , You'll need to unplug and remove the entire fixture. The inner piece of the fixture that contains the socket is potmetal and threaed into the housing. When its screwed out to access the bulb the lens can fall out too.
Thanks, i figured it out it was just a little crusty so i could'nt see the seam.
