71Demon340
Banned
I just swapped to the LBP single piston caliper brake set-up on my 71. What proportioning valve and master cyl/booster do I need to buy? I read on moparts.org that you can use a MP adjustable prop valve and a 73 or later master cyl & booster. Is this true? I still have the original brake splitter block, but probably can't use it now. Car originally had power brakes with 4-piston discs up front and drums out back. Have single piston discs up front and larger drums out back now. Thanks.
