Billib54
Member
At wits end. Have installed third MC on 62 lancer, manual brakes. All have leaked from spare port on bottom of MC. Tried various sealants and contacted manufacturer to no avail. Any ideas?
Don't think that's it. Last one bench bled, left pressurized for 18 hours with tie raps, no leaks, installed on car. Leaks at spare port. 1/4 pipe plug. No leak at brake line. Perplexed.same problem installed one of these View attachment 1715791775 seems to works so far some were installed on max wedge cars// I believe //but my exhaust manifold is right under my MC // my infrared thermometer showed a significant temp reduction///cooking your seals most likely
unused port ? do you have the right MC ?That it true. It came with a pipe plug in the unused port and is leaking around the threads.
That port is for a brake pressure warning switch. It gets plugged if car is not equipped with a warning light.
I've been really frustrated with the quality of pipe threads in many parts of late. Threads not cut cleanly, not deep enough (which translates to width also with a tapered pipe thread), etc. I would try cleaning the port really well, and using a different brass plug (not iron) in the port, with a dab of copper sealant.
