Master cylinder
For manual brakes, I believe most are using the mopar aluminum cylinder from Dr. Diff
Hmm to be honest this question might be best directed to wilwood. If your just looking for an opinion I'm thinking a 1" or 1 1/8" bore.
Riddler
I'm running a 15/16 bore master with manual brakes, this is with wilwoods all round. the larger the bore with manual brakes you are going to have legs of iron man to push the pedal down. The smaller bore you will have more pedal movement but less pedal pressure.
well i would use one ton truck master with the hydro boost on our jeeps when we built them but we were running 35 to 44 inch tires
1986 chrysler , alum, 2 bolt master cyl. you`ll have to make or buy a 4 bolt to 2 bolt adapter plate.:coffee2:
