master cylinder
THEWHITEZOMBIE
Mopars an Heavy Metal
Burney Ca.
im thinking of getting on of the alum Master Cylinders for my car an i need to know what one of the two is the one i want for my car the car is a 72 dart with a 440 fenderwell headers man vb tranny with a 4k stall 4.56's an front runner tires with 14.50's in the back! Bore Diameter 15/16"
-Displacement: 1.30 cu. in.
-Stroke: 1.42"
-Split: 63% Front / 37% Rear
-For cars up to 2800 lb.
$125.95
OR
Bore Diameter 1 1/32
-Displacement: 1.02 cu. in.
-Stroke: 1.31"
-Split 69% Front / 31% Rear
$129.95
i have willwood disk brakes in the front an drums out back!let me know if ya guys need more:thumrigh:
I'm thinking that since there is 6% difference between the two on the front and back that the 15/16 is going to take longer to stop the car. You are going to have more travel on the brake pedal than you will have on the 1 1/32.
This all might be wrong of course. LOL!
If you are going to use skinny tires up front it is most of the time beneficial to move more braking power to the back to keep from skidding the fronts. The smaller bore cylinder will take less effort but more pedal travel to achieve the same line pressure as the larger bore cylinder.
Chuck
