Mopower71
Speed Demon
Ok People,
Where is a good place to take measurements from the rear axle to body/frame, to make sure the rear is square. Also same thing for the front end to body/frame.
The right rear tire is almost resting on the front side of the wheel opening, where the left side has 1" plus clearance.
The front right tire has around 1" till the front of the fender opening, and the left has over 2". I did replace front end components so it will require an alignment. But I'm not sure it will move that far back.
