Is this with or without the slip yoke?
With the yoke you want half the length of the splines in the trans at ride height and measure to the center of the rear universal cup at the differential yoke.
Without a slip yoke measure from the same point in the rear to where half the length of the splines of your slip yoke are in the trans at ride height. Measure to the center of the universal joint cup.
It doesn't have to be exact, + / - a half an inch or so is OK.
