Mechanical fuel pump
Gator77
South Jersey
Looking for suggestions as to witch mechanical fuel pump to use is it worth spending the extra money to buy a high performance pump
no high performance pump = u need to buy a regulator
just get the cheap one at the autoparts store on online. it's all the same. at least it provides just 5-6lbs of pressure which is what you want
And check the pressure after you install. I have seen 10+ pounds with a stock parts store pump. Most carbs are happy with 5#. You may very well need a regulator.
auto zone has them for 17.00 just bought one last week its made by delphi It says made in america on the box. Don't be discourage by the arm being different mine went on and worked flawlessly and for the price i thought it was a good deal. The one on the left is the new delphi obviously.
I put this on a 72 360 and got 6.5psi on my gauge.
That's good. I don't know what NAPA and Car Quest sells. I saw 2 different ones last week that idle'd at 7+ and 10+ at rpm.
