Rodzilla
Ok, not really a mod to the pump other then I opened up the hi pressure side to 1/2" with a drill, same as my block, all choked down oil passages have been opened up as per the oiling mods thread by Guitar Jones. But my inquiry is to solve a problem on the intake side being choked off with regular screw in pick-up tubes. I thought my Canton road racing pan with bottom plate pick-up had solved that problem but I've come to the conclusion that TTI 1 7/8" headers are a no go on the rear sump pan. So I'm back to considering the Milodon road racing pan with the choked off press in style pick-up. So how about I press that pick up into my pump, plus use the Canton pick-up bolted to pump but cut off the pick-up leaving enough room to clamp a hose to it and then run the hose down along side the Milodon pick-up clamping together so its not free to flop around and the add the screen from the Canton pick up to end of hose. So now I'd have dual pick-up into one pump? Question now, is that to much volume for the pump to suck into it? Should I choke down the hose line to a smaller I.D. like 3/8" or 1/4" or something? Any thoughts or ideas?
