airwoofer
Drivetrain limit explorer
Here is the water pump from the stroker I recently bought.
http://www.forabodiesonly.com/mopar/showthread.php?t=154286
Changing to use the regular water pump with the Morose elec belt drive like the car currently uses. Only has had dyno time in it. The rear of the mounting plate shows anodizing removal from the crud that gets between it and the timing case - not visible installed and not corroded into the blue plate. Packed and ready to ship USPS "it fits it ships".
