flathead31coupe
What would be a replacement tire for that other than the Mickey Thompson skinny tires for the front? Thanks
YesAre you just looking for a street tire with those same dimensions?
Thanks...Are you just looking for a street tire with those same dimensions?
A 195/70x15 would be slightly shorter than 26, a 205/70x15 would belittle taller,and both are a little wider I think. Both should be on a 5-7" wheel. (I would run the195 on a 15x4 if I had to. )
