HI Guys has any one change there mighty demon main body to a larger one ?
I have a 650cfm and was looking at the spec's for the 650 and 750 and other than the main body with boost legs and primary and sec jet changes and high speed air bleed every thing else is the same . bowels base plate metering blocks acc pumps all the same as the mighty demon 650cfm . Called demon carburetors and the person it talk to said they did not sell main body and that it could not be done because all the pars were different. That is not what the
spec sheet i pull off there web said . but i could not find any main body that said it fit a demon carburetor. does anyone know more about this? THANKS
