mike from MRL
earthmover
in the tire smoke
nc
could you please give me a idea of how and what makes the way you do your oiling in your big blocks work?????we are also lookin to do this on my block if possible and would love to hear the reason and how to on it....looks really trick but also looks like it helps out as well. thanks mike
also if you have pics of the work that would be great thanks :prayer:
Just a guess, but by using the pressure tap to feed the top end, you can limit the cam bearing oiling, limit the top end oiling (which after the mod is fed 100% of the time rather than only a few cam degrees of pressurized oil in the factory setup) and concentrate more on the lower end. Just a guess on my part tho...
Go to our web site and sign up for the news letter, Im going to send it out again soon!
mrlperformance.com
