I've got a good running 66 170CID in my 65 Valiant. I was contemplating doing some minor performance enhancing upgrades to help bump up the HP from 101 and the torque from 155LBS-FT. It's got the factory Holley 1920 with the rod type throttle linkage. How easy will it be to swap a Super Six 2BBL system on here? Is there a decent cam to put in? I don't want to go so drastic as putting on the split header, is there any good muffler that will help it breathe better? What's the best for ignition? The next problem is I want it to appear stock under the hood, so I'd like to keep the factory air cleaner. Is there a K&N filter that would fit it that anyone knows of? It's a 4 door, 904 column shift, but don't know the gear ratio because it was originally equipped with a 225. So it might be 3.23 or 2.93.
