'64 Cuda
Has anybody here ever used the Milodon 18650 oil pump pickup tube? It's designed to work with a stock style small block center sump oil pan. I'm trying to find out if it's a less restrictive tube than the stock tube. Summit shows a pic that looks good but says that it's just a representation & the actual part may vary. Jegs shows a picture that looks exactly like a stock tube. Milodon's site doesn't show a pic of the actual part but here's what the site says about their oil pump pickups...
Engineered for maximum flow and long term durability, even in the most extreme applications.
Precision bent, thick wall tubing, of a larger than stock inside diameter.
Heli-arc welded to aircraft specs.
Milodon's exclusive high flow, compact design.
Milodon's exclusive pick-up clearance foot assures proper flow.
Engineered to work perfectly in the listed pan and application.
Can anybody clue me in on this? :dontknow:
