Mini starter terminal block
DartGTDan
'71 Dart GT Fan
metro-Detroit
I've got a mini starter (Chrysler part #56027702AC) that I plan to give to my buddy for his 512 build. The problem is it has only 1 stud/lug (for the battery feed) and the other is a molded in connector. I seem to recall that there is a kit to remove that molded in connector and replace it with a stud/lug. Does anyone know of that kit? Manufacturer? Part #?
Thanks for any guidance!:thumbsup:
Pics of what I have:
I haven't heard of any kits to convert the newer plug style to the older style stud type.
Your buddy could grab a connector from a junk yard and splice it into the solenoid wire.
Really?
You unbolt the current terminal block with the plug in and install one of these.
They used have more varieties.
You see this thread? More pictures and links in there
Hopefully you'll see a setup that will work for the situation
