[SOLD] misc box 3
Nite Moves
Belleville,ontario,canada
Up for grabs Front backing plates very good condition, Splash shield with inspection cover decent, used idler arm, and Orig. motor mounts and bolts. Rubber is not bad. seen better days. part#s are3642811 and 3642810////////// 3642819 and 3642818 Is what i found on the motor mounts take it all for $25 plus the ride...or best offer
Are those spool mounts? (in case others want to know)
And what is the trans dust cover off of?
If it a 904 cover I'd be interested.
Thank you
Cover is off a 904 mounts are off the 75 dart with a 318.Spool meaning round yes i guess they are. Still new at this thing.
The reason I asked is because the spool mounts are more desireable, and if they were spools I wanted people to know it.
I myself could use that 904 dust cover and inspection plate.
What do you think you can do on it going to AZ 86314 ?
Thanks
Thanks
I appreciate your help on the matter..really. Being new at this things can get a bit confusing. As for the shield i will PM you......Sound OK? Thanks again
