kiss
There's a variety of misc parts for my 360 LA build I need. I'm hoping someone has a donor small block engine, or better yet a donor 360, with these parts available to strip off and ship. I'm hoping someone has most/all of these parts so I can pay for shipping once, as some of these are small dollar items and wouldn't make sense to buy them individually, used, from various people. Anyway here's the list, please note I am not looking for any of these to be the chromed aftermarket ones. Please no chromed items
NEW parts if someone has them in addition to above:
Thanks guys. Again I would prefer to buy these in multiples to save on shipping. Shipping would be to Vancouver, WA 98662
- alternator brackets (with mounting bolts if possible)
- water pump pulley (AC or non AC) (with mounting bolts if possible)
- crank pulley (AC or non AC) (with mounting bolts if possible)
- throttle cable bracket for 4bbl (with mounting bolts if possible)
- throttle return spring bracket (with mounting bolts if possible)
- fuel pump hard line (from pump to carb)
- Thermostat housing (with mounting bolts if possible)
- oil tube
- oil dipstick
- distributor hold down clamp (with mounting bolt if possible)
- 360 mid sump oil pan with pickup tube (with mounting bolt if possible)
- additional mounting bolts/hardware for the engine, such as fuel pump bolts, water pump bolts, etc.
- fuel pump, standard PSI (no high performance needed)
- water pump, standard flow (no high flow needed)
- water pump silicone hose
- flex plate bolts
- torque converter bolts
- exhaust manifold mounting hardware (studs/bolts/washers/conical washers)
- correct length throttle cable for 4bbl
