Locomotion
All parts include shipping within the 48 states.
* 5 gal. aluminum fuel cell w/foam. Pair of #10 outlets and #8 return & vent w/checkball. NEW - May be Summit brand. 12'x12'x8" - $135.00
* Bronze distributor/oil pump drive for small block - Mopar P3690874. New - installed in engine but never run & removed. - $160.00
* Mopar coil P3690560 New, never used - $45.00
* 1350 billet steel yoke for 8 3/4"rear - course spline. Used but in VG condition.
Needs u-bolts. - $110.00
* U-joint strap kit Mopar P3690774. NEW - (Services u-joint conversion kit P4120714AB & for 1330 yoke.) - $6.00
* U-joint strap kit Mopar P4120469. NEW for 7290 u-joints - $17.00
* Piston rings - Childa & Albert Dura-Moly file fit. 5/64"-5/64"-3/16" low tension oil.
--RS-10477-025 (4.020" bore) - $90.00
--RS-10477-045 (4.040" bore) - $90.00
* Holley adjustable vacuum pod assembly & springs For 4160 carbs. - $25.00*****SALE PENDING*****
* Milodon valve cover breather 85682. NEW - $10.00
* Pioneer valve stem seals - 16 3/8" stem, .500" OD guide - teflon, positive stop. - $15.00
