Modern 8.25
Boltmopar
Active Member
Moval
Hello I trying search but found nothing. I have a 8 1/4 in my 73 scamp and a friend is getting rid of a rear end 8.25 from a 2000 Cherokee. Will the carrier and gear (what ever it's called ) work on my car? Any help is appreciated.
I think the axle splines are different, I would swap complete rear end if it's a suregrip take measurements make sure it's not too wide you will have to mount new spring perches
I think after 96-97 they went from 27 to 29 spline axles.
Ok thanks guys I'll measure it out tonight to see if it is worth the trouble.
