I was originally planning on keeping the stock gauges in my Duster, but then I did an ammeter bypass, then the speedometer broke, and the fuel/temp gauges never worked to begin with. I don’t like having gauges thrown all over the car so I’ve decided to make it how I want it.
I haven’t started the operation yet but whenever I get over this flu it’s going under the knife (or Dremel).
From all of the pictures I’ve seen of custom/aftermarket clusters, everyone has 2 large gauges, and 4 smaller ones. For my plans I want 2 large and 5 smaller gauges. I ordered some matching Equus gauges and a close matching AEM gauge.
3-3/8” 160mph speedometer
3-3/8” 8kRPM tachometer
2” oil pressure
2” water temp
2” volt meter
2” fuel gauge
2-1/16 air/fuel wideband.
I wasn’t sure if I could squeeze all of them into the cluster but after doing some measurements, I think I can pull it off.
I plan on cutting out the original cluster face and replacing it with a piece of black plexiglass, cut to fit the gauges.
I’ll have to figure out how to ground the switches.
If you have any input or ideas I’m all ears.
2” oil pressure
2” water temp
2” volt meter
2” fuel gauge
