540dust
New 440 Source stroker kit installed in a .030" overbore 383. Comp Cam Solid, Indy's S2 grind 280 284 .623 .615. Milodon swinging pickup external oil system and 8 qt flat pan notched for RMS Kmember powdercoated aluminum in color (steel pan). Indy 440-1 bowl ported heads and intake, with Indy 1.5 rockers and Indy pushrods. 13:1 compression, carb not included, intake is a 4150 style with 2" 4500 adapter. Stock recurved electronic distributor included, vacuum defeated. It also has a Fluidamper Balancer, double roller timing chain and chrome valve covers. Cam installed straight up at 108. $7450 Northern Central Indiana.
