Mopar 8 3/4 Pinion Angles
coronetblue
Is anyone out there using the Mopar SS leaf springs and if you are, what is the pinion angle on the pinion when the car is in the static position?
And, what type of air gap are you running on the pinion snubber to the stop (floor pan)
Coronet Blue needs your input please.
Im not using SS springs, but my snubber air gap is about 1/8th of an inch. I find this works well with MP spring clamps at the track and doesn't chop out the rubber snubber too badly on the street either.
