[SOLD] MOPAR 904 SMALL BLOCK STREET/STRIP TRANS.
dart540
south western PA.
Rating - 70%
7   3   0
JUST REBUILT 904 TRANS, CRT RED RACING H.D. FLEX KICKDOWN BAND REINFORCED1.6.CRT RED RACING DOUBLE WIDE REV BAND,STOCK DRUM WITH BLEADER HOLES AND SPECIAL SPRING TO STOP IT FROM UNWINDING ON TOP END,BORG-WARNER CLUTCHES/ STEELS,IN DIRECT DRUM,BORG-WARNER CLUTCHES/ STEELS IN FORWARD DRUM,5.0 LEVER,NEW CRT LOW BAND APPLY FULL MANUAL VALVEBODY,H.D.BAND STRUT,LIGHTENED SUN GEAR LOW/REV DRUM,REAR CLUTCH,BILLET LOW/REV SERVO,ACC.PLUGGED,2-SPRING FRONT SERVO,DEEP PAN,MODIFED CASE,SET-UP FOR TRANSBRAKE,AND OUTSIDE CASE IS SET-UP FOR REGULATOR ADJUSTMENT,OIL MODS TO CASE AND INTERNALS.NEW PUMP GEARS,VENT BLOCKED AND MOVED TO REAR,4-PINION STEEL PLANETS,FRT/REAR .
$1350 FREE SHIPPING IN USA
PM FOR INFORMATION
