Mopar M1 Tunnel Ram Plenum Top Conversion to Enderle Birdcatcher Platform
PROSTOCKTOM
West Central Indiana
Started the latest project a few weeks ago by cutting the carb pad off of a plenum top.
Ordered in some 3/8" plate I'll have water jetted out from the CAD file.
Should have it cut out next week, then weld it together, and start filing it all smooth.
I've wanted a Birdcatcher on an engine for 40 years. Might actually get it done this year.
Tom
What kind of feed rate and disc speed are you using to cut that with those discs? Are you having to use any cutting lubricant during the process?
So no carb or anything else on top? The bird catcher acts as the throttle body for some sort of fuel injection?
Yup. It’s the air valve and it controls the barrel valve for mechanical fuel injection.
The nice thing about the tunnel ram and MFI is you can move the nozzles up the runner, away from the valve cover and it will make more power every single time.
The idle can get a bit wonky but I was running a 15 pound idle check and that makes them start easier and idle cleaner.
I was spinning it 1500 rpms and cutting maybe .030" deep per pass. You just hand crank it along and you can feel what it likes.
No lubricant needed, or wanted. It's a cutoff disc and compared to using a tool in your hand this setup is rigid, repeatable, and rock solid.
Plus, you wouldn't want lubricant soaking into the aluminum pores on something you are going to be welding on.
It a very simple, quick, and cost effective way to cut the roughly 3/16" thick aluminum that leaves a super smooth finish.
Tom
No carb, just the top as pictured below, which is just a fancy air valve, a barrel valve, and belt driven mechanical fuel pump.
Then you run lines from the hat to each of intake ports where the injectors are placed. It's super old school technology, but very reliable.
The setup will have a high speed by-pass to send excess fuel back to the tank as the fuel demand decreases down track.
I am going to run my setup on E85 for a multitude of reasons.
Tom
That’s what you needed those new base gaskets for recently .
Very good work with the cutoff wheel too !
I have a FI tunnel Ram that I purchased many years ago.
It’s based on a Weiand unit for a 440,,,Enderle did really nice work .
Tommy
Tom
I like the way you think.
