65GT360
I have a complete 360 Mopar Performance crate motor with less than 200 miles on it. It is basically new and has been broken in then driven around town. The compression ratio with these heads is 9.5 to 1.
Mopar Performance 360 pre magnum crate engine
Flat top 20 over speed pro coated pistons
Cast Mopar 3.58 crank
Mopar cast rods
Mopar purple shaft solid flat tappet 557" lift cam 296 duration
Mopar solid lifters
Mopar double roller timing chain
Mopar windage tray
Mopar hi volume oil pump
5 quart Mopar pan and pickup
Mopar M1 single plane intake
Mopar timing cover with fuel pump hole
New Mopar water pump
Mopar 360 balancer
Mopar Indy head 2.02 intake 1.60 exhaust stainless valves
Three angle valve job Isky solid dual 575" lift springs heads milled
To boost up compression to 9.5 from 9 to 1.
Going with a 406 Mopar short block with Indy heads. Asking $4000 shipped to the 48 states. Pm if you need pics
Mopar cast rods
Mopar solid lifters
Mopar windage tray
Mopar 360 balancer
