[SOLD] Mopar Performance Aluminum Intake and 1" phenolic spacer
cli55er
Tem Greene's Nephew
DFW
Mopar performance aluminum intake manifold. used for less then 500 miles. replaced it with a RPM AirGap. I did not use the stock carb on this after all, so I ended up making a plate to cover the thermostatic choke hole. when I did the bolt broke off in the top, so I drilled and tapped it. yes the hole is off....fill it with some metal putty and drill it again. easy fix. or leave it and use the plate I made if you are not using a thermostatic choke. also comes with the water neck, painted clear to not rust, and a 180 thermostat.
Phenolic spacer comes with intake. I couldn't use it on the new intake as the hood would not close. brand new, never installed. box has rip in it on bottom....its a box...who cares.
New this would cost 300+ all together.
I'll take 175, plus the ride, so probably 200 or so depending on shipping method and speed.
Fort Worth Texas
PayPal or conventional forms of payment, all after funds clear.
