Mopar Performance Distributor adjustable advance?
Would be interesting if someone had an old VAT 40 Sun tester and see what the starter is drawing hot and cold. Something doesn't make sense here. I have 22 initial and all in 2,500 or so, starts easy hot or cold. No special wiring, stock replacement M&H.
I have had different battery's, 3 different starters and I just put in the last one a week ago. This one is a Power Master XS 9533. Replaced starter relay checked grounds last week I made a Positive cable in 2/0 gauge and today I made a Negative in 1/0 size but haven't tested after making the neg. cable. My car is a well maintained always cared for piece so this isn't typical but has plagued me for a couple of years. Had the biggest group 27 Auto Zone to a group 24 to a restoration battery no different. I hadn't made it a priority since the car isn't a daily driver but I'll get it sorted out eventually.
Ron
Ok update to my cranking:
After making the 1/0 negative cable so far it seems to have worked. I've only had the car out a couple of times but it is passing the warm start testing so far.
Again thank you to all for helping
Ron
