[WANTED] Mopar Performance P4876548 Water Pump
RKT
Member
Rating - 0%
0   0   0
Looking for a Mopar Performance water pump P/N "P4876548".
Thank you for the help!
They’re available. You better bring a credit card though :/
Jake
That is what I understand. However I haven't been able to locate one.
Thanks for the heads up. They are on my list to call tomorrow.
426ci R3 9.2 block, Indy w2 Heads. I recently removed the motor plate that was installed on it when it was built last year. That was when I learned I could not use the standard water pump that was installed without the motor plate. The motor plate is complicating things. I want to install Jones Racing Products pulley and belt drive system. This Mopar water pump should be the fix.
