DART5770
JW Ultra Bell #92456 Big Block Mopar to Power-Glide transmission adapter bellhousing. SFI needs recertify. $210.
Shogun drag race cooling system for Big block Mopar. Water manifold and water pump only. $140.
Hooker #5215 Big Block Mopar fenderwell headers for A-Body, Jet-Hot coated. 2" tubes with 3-1/2" collectors with turn downs. Have cracks at head flange on 2 tubes and has been repaired on a couple others. as-is, need repair! Over $900 new....$250 firm.
2.74 Low gear for 904 torque-flite. Planetary and sun shell. $100.
(2) NEW TCI 5.0 front band apply rockers for 727-904 trans. $25 each.
NEW MSD 3130 8mm Helicore spark plug wires for small block Mopar. Socket type dist cap. $50.
Milodon BB Mopar 31150 oil pan for tube chassis or dragster, deepened to 31160 spec? Approx 10 quarts. Has been repaired, but run since with no leaks. Set up for dual line swivel pickup system. Also has Stefs 110 volt pan heater. $165.
Used Isky BB Mopar roller camshaft. #RR-627. .622"-.588" lift with 1.5s. .663"-.627" with 1.6 ratio. 282^-282^ duration @ .050". 108^ lobe seperation. 4000-7500 rpm range. $150.
NEW MP P4876804 8-3/4" rearend yoke for 7290 u-joint, 10 spline. MP price $180....will take $100.
NEW Moroso 62520 solid motor mounts for B & E body. $25.
Used MSD 6T ignition box. Rebuilt by MSD. $100.
Can supply more pix of each item
Can do UPS - PayPal
Can do UPS - PayPal
