crabillac
Active Member
- Joined
- Apr 1, 2010
- Messages
- 31
- Reaction score
- 2
Car was running. I wrapped the wires. Car will not start, but gets spark. Unwrapped wires, looked for any, and all wires/connections that could be bad, and replaced them. Looked at wiring diagram for possible missing grounds, and incorrect wiring, found none. All wiring now looks good. All connections solid.Bulkhead connector replaced a few years ago. All lights accessories work. When key is in "crank" car does not fire, but after turning over and letting off of the key;I get like a 1/2 second vrooom! When I turn the key all the way off; I get a mini explosion, but not a full blown back-fire unless the distrib is retarded too much. This only happens with the key/ignition switch. I checked the ignition switch with a multimeter,(I put the red lead on the BAT lead and checked continuity for the various key positions, and the lead associated with that position) and it has no issues. I tried 12V direct from battery to coil, and did not get the vroom!, I bypassed the resistor no vroom! Checked spark plug position to cap. It is right on the money.Checked reluctor with brass feeler; it is perfect. I am running a Summit or Jegs Electronic distributor,a dual ballast resistor/ECU set-up for a 1974 Duster, but I am using the resistor only as a single. It is the same resistor that was being used when the car fired up so I do not think it is the problem. If it were; wouldn't bypassing resistor solve the problem?
I have gone through thread after thread looking for similar situations, and have tried anything that might apply to this situation. If this were your car; where would you go next to solve this problem? I am totally out of ideas. :munky2:
