Swingin1970
Complete Moroso Vacuum pump set ups
4 Vane enhanced 22644 raw finish with regulator, mounting bracket, pulley, catch can, lines, mandrel Asking $1000
- The "Enhanced Design" pulls 13.9% more vacuum than the "Original" style
- Can be used efficiently on wet or dry-sump engines
- Achieves greater vacuum sooner
- Includes-12AN fittings and mounting bracket
- Dimensions: 4.375" O.D., 5.050" back of pump to pulley mounting flange
- Versatile Billet aluminum design, well suited for wet or dry sump applications
- Engineered vane material for improved efficiency and wear
- Completely rebuildable in 15 minutes
- Mounting brackets for different applications available seperately
- Dimensions: 4.150" O.D., 5.900" back of pump to pulley mounting flange
