kiss
Okay guys, this sucks. Quick rundown, the 360 LA in my 71 Dart was rebuilt a couple months ago. Stock rebuild 4bbl intake, Edelbrock carb, pretty standard. It runs great. The engine was assembled by a friend who used the cheap valve cover gaskets that came in the engine gasket set and they leak a little bit. After searching around on here I bought the Moroso 93050 gaskets (the blue ones) to replace them.
It just has a cast head surface and I use stock valve covers. They aren't interfering with the intake manifold, I'm 100% sure of that. What I did was take the valve covers off and cleaned both the head surface and the valve cover surface very well. The old gaskets didn't stick to anything so that went fairly smooth. I also took the stock valve covers and flattened the holes against a wooden board as best I could, they're in pretty good shape, no reason why they wouldn't seal. I also bought triangle valve cover washers to spread the load a little.
With the surfaces clean I put the blue gaskets on, and snugged the valve covers down by hand with a nut driver (screwdriver with a 7/16 socket on the end). I got them pretty tight with just the nut driver which is the tightness i've always used for stock valve covers. I drove the car and they leak like crazy. I grabbed a ratchet with extension and snugged them down more, pretty snug with the ratchet gripping it close, and they still leak a bit. I'm not sure what to do. I let it heat cycle and checked to make sure they were all snug and they still leak.
I have no idea if I should try tightening them down more or not. Honestly I think they are probably too tight already, I've never snugged down valve covers with a ratchet so im not sure.
Honestly guys the only idea I have is when I took the Moroso 93050 gaskets out of the package I was skeptical right away. It's vulcanized rubber over a steel core. I just couldn't see how that would have enough 'give' to seal all of the casting imperfections. They looked great for machined surfaces, like Magnum valve cover mounting surface, but casting not so much. Does anyone else agree?
I have hydraulic lifters so I shouldn't need to open the valve covers. Should I find some cheaper rubber valve covers and just use RTV on the head and valve cover to glue it shut? If so, which gaskets should I get for that?
Any help is much appreciated.
