I'm redoing some wiring and if I remember correctly (I'll check in 30-40 minutes once I'm at the shop) my duster doesn't have a fusible link for the main wire going from the voltage regulator to the bulkhead connector. I'm doing a version of the mad electrical mod and will be putting a fusible like by the starter relay. I'll connect it to the starter relay with a ring connector but would like to have a connector where it meets the 12 gauge wire.
