Motor mount issues...need help
Cleveland57
SW Washington
Okay, the 360 is ready to be dropped into my '69 Dart. The V8 "K" member is in and I picked up a new set of trans-dapt biscuit style mount pads. I thought I had picked the correct mounting brackets (from a "reliable source") but I can't see how these are supposed to fit. The holes are off, the angles of the brackets don't seem to match the block....I've read where other people here have modified their brackets but for what it would take to make these fit, it seems easier to just get the correct ones.
Can anybody tell me if these are the right ones? If not, does anybody have a set that will work? And, if these are not correct for the 360, what are they for?
I'll provide some pictures to show you what I'm working with. Excuse the quality, I had to downgrade the resolution to make them fit.
I would appreciate any help!
Those are the brackets , where are the rubber mounts . Autozone should have them .
I have the rubber mounts. They are the Trans-Dapt #4221. If these are the correct brackets, how do they fit? Feel free to make fun of my ignorance...
Thanks
The mount goes behind the frt ear on block and captures the rear ear.
...........R u putting the curved 1 on the drivers side...is it the rite width 2 bolt on , or alittle wide 3/8 to 1/2 in.....looks 2 me that is a B+C+E body mount........kim.......
I was trying both curved and straight on both sides. Does anybody have a picture of the brackets mounted? That would be helpful!
Thanks
