My motor doesn’t have an ear to mount the bracket too right there lolAdd a longer bolt and a spacer or stack of washers between the AFT block ear and the mount.
Can’t weld but do have the old rv mounts that cam with the engine that I could try and cut up for this if they line up right.Ok. Yeah I see what your talking about now. Early 318 mount. Can you fab and weld? Do this then weld it up. Use pass side mount as a template to make the piece your missing. I copied these pix off another fabo member years ago. Figured somebody would need em. Helped another guy doing a 340 swap last week with these same pix. Other option is a 68-72 340 LH mount. Those are hard to find and expensive.
I just ran across the same issue last weekend. I did the same as moparmat2000. Mount needed to be shimmed anywayCan’t weld but do have the old rv mounts that cam with the engine that I could try and cut up for this if they line up right.
