[SOLD] Motor mounts and brackets 1972 Dart. 318
Pabuhr
Iowa
I have a set of motor mount brackets and insulators from a 1972 Dart. Good condition. I will leave it up to the buyer to decide if you want to use the rubber mounts or not. (Do you trust 41 year old rubber?) I am including the bracket bolts, nuts, and washers.
Located in N.E. Iowa.
$50.00
I have a 1983 318 with truck motor mounts. I'm changing a slant six in a 65 Dart to the 318 out of the truck.
My question is: will these motor mount brackets work on my changover?
you,d need conversion mounts from schumaker unless you change the k member to a v8 one.Then these should work.
the early A bodies all use the same K frame, its just the steering center link that is different
that being said the steel mounts will work that are being sold here but you will likely need to order thinner rubber mounts meant for a 1966 valiant with v8
like stated the k-frame on 63-66 abodies are the same for a v-8 or slant six.
those mounts will not work on a 63-66 abody though..
the ones you want look kinda like these..
