Motor question
Patch
Patch
Oak Harbor, WA. 98277
So...i have a 1991 360 out of a 4 wheel drive truck...It's the factory roller cammed engine...but NOT the magnum...and it is fuel injected. My question is...I'm using this motor in my 65 dart and puting a 4 speed behind it...what flywheel do i use? Is it the same externally balanced "old" flywheel...or does it take the newer 360 flywheel? this "crossover" motor has me perplexed at times....Thanks in advance...Pat
The 360 is externally balanced from the factory. That is unless you have it rebuilt and made it internally balanced. It is an LA block so it should still take the standard flywheel
