Took the Swinger out for quick spin today. On the way home I noticed she was losing power. Long story short the trusty 225 has developed a knock. I had plans to eventually swap in a 95 360 Magnum motor(have complete motor)and a 1975 833 od trans, it looks like my plans moved up. I did a search on here and found some answers but.....I still need a few parts and have some questions. Im going to run a carb as I already have the intake and carb. My questions are will a 650cfm carb be enough for the 360 magnum and how much fuel pressure? Will an LA360 oil pan work on the magnum motor? With the OD trans what flywheel/clutch will I need? Will the O.E. magnum exhaust manifolds work on my 71 Swinger? If not I have a set of 70 hipo 340 exhaust manifolds. Lastly I'd like to run the serp belt set up. Can I use the power steering pump and alternator from the magnum motor? How much wireing needs to be changed to run the magnum alternator,and how will affect the factory amp gauge. Thanks for any info helping me to get my Swinger back on the road.
