[SOLD] Moving sale lots more to come
drive48
MILK MAN
connecticut
Took a job in Germany so all parts need to be sold.
need something ask soon as whatever i don't sell will get trashed,scrapped,or put in storage at a relatives home.
  • 70-71 unsilenced unrestored aircleaner and valve cover breather $250 and the ride box dimensions 23x23x6 15lbs
  • misc engine parts $ 20 and large flat rate box
  • 8.75 3.23:1 ring pinion yoke u joint and hardware $50 and large flat rate usps
Also interested in gear set if for 742 case
PROSTOCKTOM said:
I'm interested in the gear set depending on what case it's for.
Those are for a 489 case. You can tell because the pinion shaft is tapered. It's a fine spline pinion also which I believe was only used in the 489
Drive 48 if none of the others take them I'd be interested in the gears/yoke as long as the gears are a matched set and in good shape.
those are for a 489 case. You can tell because the pinion shaft is tapered. It's a fine spline pinion also which i believe was only used in the 489
drive 48 if none of the others take them i'd be interested in the gears/yoke as long as the gears are a matched set and in good shape.
489 i will get close ups
it is matched set i took out to put 3.91's in its place
More pics as requested of air cleaner..
SOLD SOLD SOLD SOLD THANKS FABO AND TS318
I believe the applications are correct as followed but verify as needed.
I can't take this with me and would like to have someone save these and put them to use. Hit me up $.
  • 3614395 71-73 drivers side 318 2465767 65-68 passenger barracuda 273-318 i had these on my 69 fastback until i sold it last year $80 set and ride or will break them up
  • 2863553 68-70 drivers 340 $150 and ride
  • 2951123 68-69 dart 318 drivers $25 and ride
  • as a set only 3418623 340 passenger 3614368 hp late 71-74 340 manifolds off a duster $220 set and the ride
  • 2463107 i believe c body 440 manifold $25 and ride
Air cleaner sold...
Exhaust manifolds available make reasonable offers.
If not sold all 340 manifolds will go in trunk of the 72 duster 340 4 speed i'll be listing to sell online/locally and the rest get scrapped.
