[SOLD] MP purple shaft .590/.590 lift solid cam #P4120657AE
physixx
Edison, NJ
I have for sale a MP purple shaft small block cam #P4120657AE. It’s a solid lifter cam with .590”/.590” lift and 265/265 degrees duration at .050” lift. Useable RPM range is 4000-7500. There are no lifters with this cam. It was in 340 bracket engine that I recently purchased that sat for 28 years on an engine stand and was never rum. I believe that this cam never saw any run time. The assembly lube that was used back then looks like it stained the metal but from what I can see, all the lobes look perfect, except for the staining.
https://www.summitracing.com/parts/dcc-4120657
This is a wild cam and is designed for racing. I would like to get $60 for it plus the shipping.
Ken
Edison, NJ
