IRISH RT
Hi Recently purchases an E Curve non Vacum, I have read the instructions but find them difficult to find what my advance curve should be , How do you determine curve m Do I set total at idle then subtract by taking timing out via the two dials , For example it was initially set Dial #1 @ 1 and Dial #2 @ 7 that was with 10degrees initial , Then had a play at Idle with the dials and set it up #1 @ 3 and # 2 Dial @ 7 the the initial changed to 30 degrees on the pulley took it up to 2500rpm and timing didnt alter much, So if you have a 360 ported heads etc Plz advise me the simple method to get the best results Thanx
