Terry8675309
Active Member
I have new dizzy and carb as well as 8.5 mm msd wires and blaster 2 coil( OIL FILLED). The installation instructions kinda suck. I set my initial timing at 12 deg BTDC. I can get the engine to idle but it sounded like crap. I pulled all the plugs and they had major signs of preigniting. I am not running any vacuum advance. Do I run more initial timing to solve the preignition problem? I do have new plugs installed and gapped at .036 Also does my gap need to be larger now that i threw out the stock ignition and upgraded to the MSD Digital E Curve?
