You cannot simply change to regular lifters from mushroom lifters. You have to change the camshaft too, because it is ground to a different, more aggressive ramp rate for the mushroom lifters.
That was the whole point. The mushroom cam was the forerunner of the roller. Much more aggressive ramps. So much so that more lifter face was needed to facilitate proper lifter to lobe contact.
