My 69gt Project
kybatman
The Original Bruce Wayne!
Bowie, Texas
I will be posting photos to track the restoration of my dart.
I will be as organized as I can.
Bruce
[/URL]
new 8 3/4 housing, 849 case with 2.94 gears.
Thanks to sedanman for the new chunk.
with the new welds..
Rears:
15 x 7, 5 on 4.5 with 5.25 Back spacing
Fronts:
15 x 6, with 3.0 back spacing.
These pics are from the day I bought the car.
It was just a vision in my head, or maybe an aneurism..
Bruce
Keep your chin up.
Mine is going to slow for a bit while I finish removing the trim and such.
Once I finish that, it's off to media blasting, and then things will pick back up .
Going to recover over the winter,( physically and cash wise) what little bit of that we have here in Ft Worth, and then back at it hard this spring.
Bruce
Very cool 69 GT. My project has kind of ground to a halt.
Looks Great! Are you using the stock width rear end? Are you or did you move the springs into the frame rails to run a wider tire?
removed the small rear end, replaced with 8 3/4 out of a b-body, did not have to move the leafs to run the 5.5BS rim.
Did move the spring perches in on the rear end though. about 1.5 inches on each side to match the stock leaf location.
going to have to remove a little bit of the lip on the fender.
I could go to a smaller sidewall tire but the 245/60 looks awesome under it.
Bruce
Your rockin right along! You'll be driving before you know it.
with the new disk brake conversion mocked in.
If that's the Dr Diff 10.7" rotor kit, I can't really tell, I believe the caliper is supposed to be towards the rear of the car. The bleeder screw needs to be facing up. Nice work so far. :D
