Sorry for the lack of updates guys. Let me start where I left off with. I'll try to bring everyone back to speed.
When I left off I was working towards getting some tubs fabbed. Well that didn't exactly get done. I ground the welds smooth and sprayed a layer of weld through primer over the seams for the tubs.
http://i1173.photobucket.com/albums...r 440/IMG_20140318_134247_086_zpsa2f74435.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140318_134305_058_zps90d7a9e3.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140318_134752_723_zps2fd922ca.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140318_134807_919_zps7bd68d56.jpg
After this was done my attention was diverted to the rocker panels and door jambs which needed some serious attention due to the "four letter" word.
http://i1173.photobucket.com/albums...r 440/IMG_20140324_133029_937_zps2ff93593.jpg
I cut out the bad in the door jambs and roughed them to shape to accept patches. Unfortunately I didn't snap any pictures of this. The bottom of the jambs where easy enough to remove the rust and leave good metal behind without the use of a sand blaster, but the rockers not so much. I tried to use my harbor freight spot blaster to clean up the areas but it was not powerful enough to do the job and I wasn't happy with the result.
Two big problems soon showed their faces.
I was in a tight spot when this happened as the end of my senior year was fastly approaching. I need to have the car taken out of the shop before school ends. I had a lot of work ahead of me that I wouldn't be able to do without fixing the rockers. After patching I still needed to make the tubs, fit the quarters, replace the trunk gutter rail, and weld in the tail panel. All of this was needed to be done to make the car solid once again so I could move it.
That was one big problem that I had to figure out, but there was an even bigger issue I needed to figure out. Where the hell am I going to bring it back to. I don't have my own garage at my house. My grandma who lives next door has one that I used for a short time with the parts car. Problem is that the floor is cracked, messed up, and tends to flood when a big storm rolls through. NO place for doing delicate work on my car in this kind of shape. She also is in use of the garage currently so even if I wanted I couldn't use it. For the longest time I was planning on bringing her to the body shop I worked at. Unfortunately the shop had moved to a smaller location in the same area and hit hard times. I was laid off and they had no room for the car in the now smaller shop.
These too problems could have derailed my project. I was torn apart by all the work that still needed to be done, the deadlines I wasn't going to make, where she was going to go, and being laid off from a job I loved. I almost gave up at this point, but I knew in my heart that I need to finish her and do it right. So here is what I did.
First lets tackle how I was going to move the car when It was in so delicate shape. First thing I did was get some epoxy primer and prime all the bare metal. All bare metal was coated with about 3 coats. This was done to protect it where ever she was going. I was floored to see how flat the roof came out with no body work done. I also sprayed the deck lid and doors, even know I doubt I will use either of them. I have better, rust free and straight doors on my parts car. the deck lid is still to decide.
http://i1173.photobucket.com/albums...r 440/IMG_20140522_123706_811_zpsf25480b0.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140522_123731_964_zps7188a1ef.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140522_123805_622_zpscb6335be.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140522_123822_567_zps018bb894.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140522_123949_132_zps1eb26d64.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140522_124018_714_zps9e116dbb.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140522_124037_026_zps6cbcca38.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140522_124125_470_zps7cf002f2.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140522_124144_466_zps3cec1b0d.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140522_124224_560_zpse7c99af9.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140522_124301_523_zps493456fb.jpg
It had runs and was not perfect, but it was my first time priming. Its not final, just to protect the metal in the mean time.
I decided in order to move the car It was best to stiffen up the car the best I could. So I dead-leveled the car on jack stands. I got some angle iron and welded the hinge pillar to the door jamb.
http://i1173.photobucket.com/albums...r 440/IMG_20140522_134842_803_zpsfc2d0b67.jpg
After that I welded the front sub-frame to the back sub-frame with some square tube.
http://i1173.photobucket.com/albums...r 440/IMG_20140530_131647_481_zpsd4efb498.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140530_131656_384_zps16c7df45.jpg
Then I welded the roof support to the frame rails with angle iron.
http://i1173.photobucket.com/albums...r 440/IMG_20140530_131716_240_zpsf8782c86.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140530_131730_218_zps1cfd8a07.jpg
I brushed all the welds and sprayed some cheap paint over them to protect them.
So with the car stiff I still needed to be able to get it on a flat bed trailer. But how was I able to do that without the rear axle. I decided the best way to do this was to use a body dolly/cart. I didn't want to buy one because they are very expensive for what they are. So with a little internet and DIY I made a cart out of 2x4s, 4x4s, and some solid casters. I jacked the car up using a couple floor jacks and some scrap wood and slid the dolly under just like that. The k frame, steering, and front suspension where all then removed.
http://i1173.photobucket.com/albums...r 440/IMG_20140605_125437_347_zpsab01d786.jpg
http://i1173.photobucket.com/albums...r 440/IMG_20140605_125546_843_zpsa4a5b3e6.jpg
You can imagine all the parts I had accumulated around the shop from the two years she was there. So I took a week to drive my truck over and bring them home one truck load at a time. I stored the parts anywhere I could at home. All the this priming, body stiffening, dolly build, parts hauling I did in about 1 1/2 weeks. Which for me was super fast given the limited shop time I had to deal with.
A week before the last day of school (last Friday), the car was loaded on a friends flatbed trailer no issues at all. The dolly performed flawlessly and will be useful when being worked on as well. Not bad for a days work and $150. Also we where able to fit the car which is about 15ft long on a trailer which is only 12ft.
http://i1173.photobucket.com/albums...r 440/IMG_20140606_174402_216_zps24ea621f.jpg
http://i1173.photobucket.com/albums/r592/mejackg/1972 Duster 440/100MEDIAIMAG0214_zpsfd97a3e9.jpg
Well I can now say that she can go at least 65mph.
http://i1173.photobucket.com/albums/r592/mejackg/1972 Duster 440/100MEDIA36IMAG0215_zps68b60a0a.jpg
But wait aren't I forgetting something? Something important? Oh ya! Problem number two. Where the hell am I going to bring her? I had no place. Well that's where I was saved again by my good friend with the flat bed. He has a garage in the back of his property. One side is a finished garage which he uses frequently for his own projects. On the other side is an unfinished pole barn that he was planning on finishing for 20 years. Instead it was used as junk storage. So when he heard of my little dilemma he offered the area to me. Right now it has a dirt floor no insulation or lights. But we are studding all the walls, insulating and sheeting the walls and ceiling, installing fluorescent lights, a garage door, and the best most important part, pouring a new concrete floor. In the mean time I am able to store the car in his side of the garage until the new garage is finished.
http://i1173.photobucket.com/albums/r592/mejackg/1972 Duster 440/100MEDIAIMAG0216_zps6f47612d.jpg
Sorry for the bad picture.
Here is what we are turning into my own little shop. There I am shoving some insulation in the walls right there.
http://i1173.photobucket.com/albums/r592/mejackg/1972 Duster 440/100MEDIAIMAG0217_zpsc2896c95.jpg
So then if all goes to plan I will have my own little shop for her by the end of the month. now I just have to save all my pennies to pour a 12x30ft concrete slab.
