redlightrich1
Active Member
Hi All, this is my first post, and I already searched and the images will not load. I am looking for pix that show different degrees of wear on the mainshaft gears of an 833. I am talking specifically about the "lead in" ramps" or the teeth behind the brass syncro rings. I understand they will develop some wear, but what degree is useable, and when are they junk? Also, is there any type of file or stone recommended for removing burrs or sharp edges? I am in the midst of my first tranny rebuild and would prefer to do this once and right the first time, but the cost of mainshaft gears and input shaft is big, so if mine are good, I would like to use them. If not, then I have no choice but to pay up!! Any help would be great.
Thank you
Rich
Thank you
Rich
