I haven't been keeping the pic up, so I'll start now that the Motor is almost built Basically she started with a wore out 360 Small block motor, She had bad bearings. After I pulled the motor and started disassembling it I found that she needed a bore real bad, also the crank was shot to hell. So I started with the full teardown.
I started with having the block bored .030 over. A set of Keith black Pistons, A medium performance cam, and a zero deck job on the motor. She got a nice chemical bath and all the bearings from cam to crank got replaced. Set of cromemolly rings <yes, gapped correctly > I didn't take many pics, but here she is before the shop cleaned her up, you can see the years of paint are starting to get stripped off .... By me and then by the machine shop.
<no picking on the mustang in the background
not that everything Is back, I cleaned the block one last time, set in the crank <nice and turned .010> Cam, pistons, double roller.... time to get er done
After much conversation. I decided on the Gold, Black, and chrome look. With a black engine compartment. I think it will look great. Here she is as she sits now. The heads where just on while paint was being applied. They are getting ported and new springs, ect, ect...
Now, being the anal person I am, all the lettering and freeze plugs are getting painted black. I'll Most likely paint some Mopar Logos on the motor as well. The transmition has been stripped, cleaned, and sanded.
Ohh, I pulled this out of the old oil sump..... I think I know why the motor went bad. There were metal shards, glass, and plastic in the motor
more updates as I have the time and pictures
