Get ready for a long post..
At the local yard, for the last six months or so there has been this 383 missing one valve cover and no distributor or carb on it getting rained in. Thursday afternoon, something told me I should go buy it.
Went out there and bought it for $80, which I thought was too much. Got it home and pulled the intake off. Intake ports were standing full of water. Pulled the heads off and 2 cylinders were standing full, BUT surprisingly every hole was nice and shiny with no rust. Cleaned the water out.
Pulled the drain plug out and got a gallon and a half of water and a small amount of oil. Pulled the pan and everything had a nice coating of oil on it. Pressure washed all the oil/water gunk out.
Put some oil in the cylinders and let it soak a few hours, and the engine came loose without too much effort. All bores look good all the way down and there isn't a noticeable ridge at the top. Exhaust valves were white and exhaust ports were clean, so I guess it was running clean.
Cleaned everything up good and painted it. Put it back together today and it's almost ready to go in my 76 d150, except I have a question about oil pans. I know this isn't an a body, but this forum has a lot more knowledge than the truck forums.
Does anyone know if a car pan will clear on a truck? It doesn't have much of a sump, which makes me think there is a chance. I used my only truck pan on my d200.
Also, Engine is a 66 4 barrel, which decodes to be 10:1 and 325 Hp.
Thanks!
Thanks!
